05 pacifica trani leak HELP !
Old Apr 11, 2013 | 11:47 PM
lilrobert1's Avatar
Default delete post
New to forum and first post SORRY but i need HELP!
05 PAC front wheel drive... leaking oil out of transaxle rear cover not pan,
seems like a easy fix take cover off and clean add atv/rtv and reinstall
Question is the oil different than whats in the pan (atf4) smells like the same stuff any help would be greatly appreciated
Old Apr 12, 2013 | 06:34 PM
Djinn-n-Tonic's Avatar
All Chrysler products after 2000, (Actually even earlier, not sure of the year but in your case it doesnt matter anyway) use ATF+4 exclusively in their Automatic transmissions. The one exception, would be the Chrysler/Dodge models with a CVT trans...(Once again, no matter to you.). Using ANYTHING ELSE is a recipe for disaster.
Take a look back a few threads, this was just discussed not long ago. As long as you can without a doubt verify a cover leak, and the case is not cracked, RTV is used to reseal the cover, and call it a day.
Oops, I misunderstood.... There is no "Gear case Oil"...its integral with the trans. Filling the transmission, also fills the gear case. There is no seperate fill location. Just top-off the trans fluid in the usual way when you are through.
Old Apr 13, 2013 | 04:03 AM
lilrobert1's Avatar
Thanx Djin n ton your are very helpful
Only306
Nov 17, 2011 07:47 AM
HARLEY_OWNER
Oct 19, 2009 05:50 PM
touch down
Aug 27, 2009 09:20 PM
sunshinegrl
Dec 27, 2007 08:26 PM
garr5859
Aug 21, 2007 11:51 PM
