07 Pac
Old Jul 12, 2018 | 10:39 PM
Brent Mason's Avatar
Default 07 Pac
i’ve been having no crank no start on this car and have had no luck ! Linking error at DLC and immobilizer light on steady . Had a new immobilizer and key installed and have same . I found a badly corroded ground on drivers side and repaired it ( while reconnecting the ground at least one or maybe more relays rattled) ! I am not sure what the trans gear selections on the dash should look like but they all have boxes around them . Would A bad TRS cause the immobilizer light tonstay on and no crank ? Any other grounds I should look at ? I have never had car running because I bought as project . All fuses work as should . PCM seems to being sending signals out but not comunicating with key/ immob. So I am looking for ideas to trace the problem without a DLC comm.
354larry
Mar 11, 2019 02:53 PM
Brent Mason
Aug 21, 2018 11:38 AM
Brent Mason
Jul 10, 2018 06:45 PM
ROb B
Sep 8, 2008 08:16 PM
snagelpuss
Aug 22, 2008 02:58 PM
