New keys programmed but not talking to computer
Old Jul 5, 2018 | 08:33 PM
Brent Mason's Avatar
Default New keys programmed but not talking to computer
I have 07 Pacifica , bought as a project and the only key I got from seller did not have a battery ! Had a locksmith come and he programmed a new key to a new immobilizer . He took the old immobilizer and the new one to his shop and pulled the info from the old one and programmed the new key ! When we installed everything he said the computer is not communicating with the key . He said if I got another computer he would program it fo $50 ( that’s fair) . My question is if the computer is bad ? I have check all wiring as thorough as I can and see no bad connections or fraying . Also I get a linking error when connecting the Code reader . So unless I am missing something I would assume the computer is bad ? Any other things I should consider ? Thanks
Old Jul 6, 2018 | 02:27 AM
BiliTheAxe's Avatar
Disconnect the car battery for a few minutes to reset the system.
Old Jul 6, 2018 | 08:47 PM
ok well first I have no idea how he can program a key or a skim module when its not installed in the car?? If you replaced the skim a scanner would need to be used to transfer the VIN and skim key code to the new module. There is a procedure for this in the scanner. Then you program the keys. SO how he managed to power up a skim module and program the module is a new one to me.
Old Jul 12, 2018 | 10:16 PM
Took old module and pulled vin etc out and installed to new !
Old Jul 13, 2018 | 11:50 PM
pulled out how? need power to even get teh nodule to work then need an obd 2 connection to be able to talk to it.
quakerj
Oct 4, 2019 10:30 AM
Xanthorpe
Feb 9, 2018 08:45 PM
Mikey722
May 9, 2016 09:34 PM
thewheelman
Dec 12, 2013 04:45 PM
johnjr1266
Jun 29, 2012 09:38 PM
