2004 Chrysler Pacifica has no power after wreck.
Old Oct 7, 2010 | 05:43 PM
ktaylor101988's Avatar
Default 2004 Chrysler Pacifica has no power after wreck.
I was in a collision a couple days ago. I was going 35-45 mph when I hit another car in the rear end. they hit two other cars. My driver, passenger, and knee air bags deployed. My car was damaged in the front. As soon as the wreck happened, the car shut off and all the power was off except for the inside lights. They came on but was flashing. When we took the grille, bumper, and radiator off, you could see a group of wires had been smashed between the radiator support and frame of the car. We pulled it apart and checked all the wires, none of them was cut. We unhooked the battery for several hours and tried hooking it back up and the only thing that came on was the lights on the DVD player where you insert the disk. They was flashing. Nothing else would work. I do not know if there is some type of safety switch that would cut off everything or if this is a computer or electrical problem. I did not have full coverage so I am trying to repair the vehicle myself. Any suggestions or help? Thank you! Kim
Old Jan 18, 2012 | 05:18 PM
jcthies's Avatar
Default similar situation
I have had a similar situation with the electrical occur in my 06 pacifica. I rear ended another vehicle doing 10 mph. front end damage only. the car was taken to the body shop and repaired. 6 months later, I am having odd problems with the electrical system in the read of the vehicle. The navigation nor the rear hatch alarm will work. And when I put the left turn signal on, it makes a noise indicating that the light blub is out when they aren't. Took it into the dealer and they told me to get a new nav system and new hatch alarm - crooks. Any ideas what the problem could be?
GOVOLS123
Apr 8, 2014 05:44 PM
XSIV8
Jan 28, 2014 10:13 PM
Stefan
Dec 8, 2011 11:17 AM
Evapa
Jan 7, 2009 12:11 AM
kansasdarkman
Dec 26, 2006 12:30 AM
