2006 Pacifica Problem with Front A/C Blower
Old Jul 21, 2014 | 10:04 AM
martywj's Avatar
Default 2006 Pacifica Problem with Front A/C Blower
The problem started with the blower not coming on at all when the car is first started, but it it will start running after about 3 to 5 minutes. The rear blower works fine.
The next issue is the front blower will come when the the car is first started and blow like gangbusters for 15-30 minutes of running. Then the air flow will gradually diminish until there is nothing.
I thought the system was low on refrigerate and freezing up, so I had it serviced and everything is ok. The mechanic said that I may have a blower going as he felt like the air blower speed was varying speed on its own(pulsing).
The question is do I have a blower problem or resistor pack problem or both?
Any help would be appreciated.
Marty
Old Jul 21, 2014 | 01:58 PM
cirrus98's Avatar
I would say a blower motor problem. If it were the resistor, the fan speed would probably be stuck on high only.
Old Jul 21, 2014 | 05:47 PM
Next time it stops blowing kick it with your foot it it starts back up bad motor
Old Aug 6, 2014 | 08:13 AM
martywj's Avatar
BTW, the system in this car is the automatic dual temp control system. Looks like it is the blower. Does anyone have a part # for the front blower for this setup?
Marty
Old Aug 6, 2014 | 09:43 AM
depends on who u get it from
Old Aug 10, 2014 | 08:41 PM
martywj's Avatar
Thanks for all your help???
Old Aug 10, 2014 | 08:49 PM
cirrus98's Avatar
The dual temp control has nothing to do with the blower motor itself. Just go to a scrap yard and pull one off any old Dodge Caravan/Chrylser T&C from 01' to 06'. That's what I did(off a Caravan), put a small amount of WD-40 and presto. It was a 10$ fix. Easy fix, if you want, I can send you the link.
bruce_uk1
Aug 18, 2015 03:52 PM
imnotmarvin
Aug 2, 2014 07:34 PM
Cardsmall
Feb 23, 2014 07:36 AM
mikeinoz
Sep 2, 2010 08:34 AM
PacChi
Feb 12, 2009 11:42 AM
