2006 Pacifica TPS reset
Old Jun 10, 2007 | 03:33 PM
zimba's Avatar
Default 2006 Pacifica TPS reset
How do I reset this? I had to buy a new tire and now it constantly tells me to reset the system. I find it hard to believe every time you rotated tires or fixed a flat you would have to take it to thedealer as the manual says.[/align][/align]thanks[/align]
Old Jun 10, 2007 | 06:45 PM
xfire04's Avatar
Default RE: 2006 Pacifica TPS reset
you need a round magnet that goes around the valve stem there is a sequence to do need to take to the dealer
Old Jun 10, 2007 | 07:19 PM
the 04 and up will relearn if the tires have been moved. U say that some one replaced a tire?? most of the time when i see some one do that they snap the sensor when they reinstall the tires.
Old Jun 10, 2007 | 08:02 PM
zimba's Avatar
What does the sensor look like? it was just a small item at the bottom of the stem? Was it supposed to have a black box like I see on the internet? We looked inside the tire and did not see anything so we assumed the small (looked like a lead fishing weight) oval at the end of stem was all there was to it. Is there a way to turn off the notification? I don't care if it works I would just like to see my compass and MPG.
Old Jun 10, 2007 | 08:09 PM
xfire04's Avatar
the tech cn tell you more
Old Jun 10, 2007 | 09:50 PM
the main part of the sensor is inside the tire where it will read pressure. The stem will be hard and wont more. And no u cant turn it off its a federal goverment thing.
mopwrd340
11
Jun 30, 2023 12:05 AM
jdsaengine
Jun 15, 2009 04:15 PM
tmp03tnc
Mar 29, 2006 04:19 PM
davesan
May 13, 2005 07:05 AM
electrocuda
K-Cars
Apr 21, 2005 07:06 PM
