Any special tools needed to do the rear brakes on a 2006 Pacifica
Old 03-07-2012, 10:57 PM
wilcom's Avatar
Default Any special tools needed to do the rear brakes on a 2006 Pacifica
My parking brake is out of adjustment so I figure the pads are worn out. I'm going to do the rear brakes tomorrow. Are there any special tools that I will need? Special something to back off the pad adjustment? First time brakes on a Pacifica.....thanks for any help
Joe
Riverside, ca
Old 11-01-2012, 09:31 PM
Fisherguy's Avatar
I'm in the same boat, can you just use a c-clamp to push the pistons in or?
Old 11-02-2012, 09:26 PM
cirrus98's Avatar
On the driver side, there will be a small rectangular rubber behind the assembly. Remove it to adjust the resistance for the parking brake. I don't know what the tool is called but it need to be in a "L" shape with a wide flat side at 1 end. Keep in mind, these are not my pictures, just re-posted from the web.
Attached Thumbnails Any special tools needed to do the rear brakes on a 2006 Pacifica-62217_adjust_2.jpg   Any special tools needed to do the rear brakes on a 2006 Pacifica-brake-adjuster.jpg
Old 11-05-2012, 08:20 AM
Fisherguy's Avatar
Ya, same as my truck, should be one on each side.
In the old days they made a separate backing plate for the right and left sides, now they use the same one, just rotate it, the right side is at the bottom, the driver's side is on top so adjusting the driver's side (on my truck) is practically impossible unless you take the wheel/tire off and use a mirrir to see what you're doing.
fjinnes
47
01-12-2015 04:02 AM
VoyagerPig69
04-27-2013 01:03 PM
syco26
02-28-2010 12:38 AM
blanegardner
02-07-2010 12:21 AM
XFIRETECH
11-09-2007 12:49 PM
Quick Reply: Any special tools needed to do the rear brakes on a 2006 Pacifica
