Brake fluid: dot3 or dot4?
Old Jun 25, 2016 | 07:38 PM
oea's Avatar
oea
Default Brake fluid: dot3 or dot4?
As per title, it doesn't say on the manual and I can't find any useful info anywhere on the net, not even here.
It should be a simple question for most of you here, right?
Pacifica 2004
Thanks so much!
Old Jun 25, 2016 | 07:45 PM
bridanne's Avatar
DOT 4 has superseded DOT 3 in most cases.
Old Jun 25, 2016 | 08:11 PM
oea's Avatar
oea
Thanks!
So I should replace it because I don't know what's in it, or you think it's already dot4?
Just trying to figure out if mine is one of those "cases".
Thanks!
Old Jun 25, 2016 | 08:25 PM
bridanne's Avatar
DOT 4 has been the standard since 2006 and is fully compatible with older DOT 3
Old Jun 25, 2016 | 08:27 PM
bridanne's Avatar
Mine is a Stonewhite 2004 Pacifica, and I am running DOT 4
Old Jun 25, 2016 | 10:21 PM
oea's Avatar
oea
OK, sounds good, so you think I can top up with Dot4 regardless of what I have already in the system? I know it would be better to flush the whole system, but otherwise, they can mix, right?
Thanks!
Jberger
Feb 23, 2013 09:47 PM
rodger
Aug 6, 2010 05:39 AM
sargevrod
Aug 4, 2009 10:00 AM
phatboyfromla
Apr 29, 2009 05:18 PM
01sebringphanatic
Mar 21, 2007 05:34 PM
