crank but dosn't start
'06 stoped running, had to replace the crank, cam, map and throttle sensors and then fuel pump and fuel modulator. all these came up as engine check light codes. Van cranks but still dosn't start. no more codes. however the check engine light flashes 10 times. last to replace was the fuel modulator, while tank was still on the ground it ran. fuel pump is 3 months old. put tank and driveshaift back in and back to cranking but not starting. getting no movment from from the rpm guage. put a new battery in it.(old one was 4 years old). tommorow will look at the ground wire fix i've read about. i'm 58 and pulling that tank out is not easy for me. fuses are all good. if i spray starting fluid in it, it runs. anything else to look for before i pull it out, again??
