Factory DvD on 05 Pacifica
Old Feb 20, 2008 | 01:30 PM
Coma's Avatar
Default Factory DvD on 05 Pacifica
I just bought a used 05 Pacifica Touring. I have played around with the DVD player but cannot get backups of DVD discs to be reconized by the DVD player. I am using a DVD-R for the videos. Any one make backup of DVD's and get them to work in the factory DVD player? I hate using the new copies b/c the kids do not care for them and they get all scratched up.
Old Feb 21, 2008 | 09:54 PM
Coma's Avatar
Default RE: Factory DvD on 05 Pacifica
Any one used a backed up DVD?
Old Feb 22, 2008 | 09:57 AM
PacificaBus's Avatar
When you say back up what do you mean? Are you making a copy of the DVD? Do they play in your standard home DVD player? It could be how you're making the copies.
Old Feb 22, 2008 | 02:48 PM
Coma's Avatar
Yes I have no problem playing them in the home player. I have to use DVD-R's tho for it to work. I just cannot get them to read in the Pacifica DVD player in the Pacifica.
Old Mar 1, 2008 | 12:37 AM
mrfixit454's Avatar
Coma,
I checked a few of my DVD's this afternoon. one DVD-R worked. One +R did not. Another DVD-R did not work then after I ejected and inserted it back in, it worked. I did not check the +R again to see of it would play.
One thing I notice is that it takes quite a bit of time to read the home burnt disks before they play. Mine is an 04 w/ the RBP radio (Intermezzo version) and 6 disk DVD w/ IR headphone system if that helps.
Old Mar 3, 2008 | 09:19 AM
As mrfixit454 stated it might be the type of disc you're using. Also some brands of discs might work better than others, I've seen this happen before.
Old Mar 6, 2008 | 04:22 PM
snagelpuss's Avatar
Don't know about just the pacifica dvd player, but a lot of machines won't play dvds that are burned because they are dvd+ or dvd-. The factory dvds are made as advd rom and most all players will play them. I had the same problem with my dvd player in my 02 Montana. I bought new burner for my computer and it came with software that will let you burn a copy of a factory dvd on to an DVD+ and you can booktype it to burn as a DVD ROM.
My burner is a benq and it comes with a software program called Q-Suite and it has a setting to booktype all DVD + to DVD ROM. You can only Booktype DVD+ not DVD-. So you need to by DVD+ media copy it in your benq burner, you can use dvd clone, dvd shrink or what ever other burning software you have. But put the DVD+ blank in the Benq and have your Q-Suite set to booktype DVD+ media to DVD rom and they should all play in your pacifica, I have not found a player yet that won't play a burned DVD set up as a DVD ROM.
You can do a search on the internet on the benq dvd burner and Q-suite. A good source of information can be found on www.cdfreaks.com
Hope that helps.
Old Mar 7, 2008 | 09:19 AM
moe's Avatar
moe
i've heard from techs that the darker the disc is you burn on the better.i've tested this, and found that if you write on the lighter dvd's with a pen ,that the player will skip over the pen mark.when used in most car players.think it has to do with density<might be spelled wrong moe
crankycowboy
Jan 13, 2013 02:19 PM
mommymobile
Dec 4, 2010 11:50 AM
gallam03
Oct 1, 2009 08:26 PM
gallam03
Oct 1, 2009 02:12 PM
RBlatt6011
Apr 20, 2008 01:19 PM
