It's hot and I need A/C help, 04 Pacifica!!!
Old Jun 20, 2008 | 07:25 PM
RobW's Avatar
Default It's hot and I need A/C help, 04 Pacifica!!!
Have an 04 Pacifica and the AC seems to be dead. I checked the fuses and relays. Swapped relays from places that I knew that fuction worked, made no change. Took the AC relay out and tested the ports under it. From the front of the vehicle the two on the left were hot at all times, with the snow flakeon the HVAC unit it did not change, left two hot, nothing else. With car running. On and off on the HVAC controls, no noise from the AC clutch. Held the recirculate and power button on the controls to reset, same results. HELP PLEASE! It's getting hot here and momma needs her AC!
Rob
Old Jun 21, 2008 | 10:40 AM
ladisgsx's Avatar
Default RE: It's hot and I need A/C help, 04 Pacifica!!!
you might have a leak, take it to a pro. they at least can tell you whats wrong with it.
Old Jun 21, 2008 | 06:38 PM
RobS's Avatar
If the AC clucth isnt engaging, this may very well be due to no/very low 134A, is the refridgent pressure sensors, says there isnt enough refridgent iin the system, it will tell the PCM NOT to let the A/C relay turn on, because, the compressor will be damaged by running with refridgent, since the refridgent has oil in it which lubes the inside of the compressor
Old Sep 24, 2008 | 02:34 PM
STIGuy's Avatar
Have spent about $2700 ot get my '04 Pac A/C fixed. The dealer said the A/C system was empty (no freon). Also said the A/C compressor clutch was shot.
Spent $1300 to get the compressor and dryer replaced and system charged. Worked great for about 2 weeks. Slowly started putting out warmer and warmer air. After 5 trips back into the dealer about every two weeks,where they added freon w/ tracer die, they could not find a leak ($50 each time).
Finally went to another mechanic and he found the leak in the A/C coil in the dash (next to the cabin filter). Cost $1200 and two days to COMPLETELY remove the dash, replace the A/C coil andput the dash back in the car.
Been a month and the problem seems to be fixed now. I suspect the compressor and dryer was a waste of money.
Jason1969
Jul 8, 2013 09:35 PM
kimkromann
Jul 11, 2010 05:17 PM
RobW
Jul 5, 2010 08:25 PM
jazzypug1
Jun 30, 2009 05:48 PM
jdman1
Jul 22, 2005 05:08 PM
