Oil Pressure light
Old Jan 10, 2021 | 02:29 PM
cardude1223's Avatar
Default Oil Pressure light
My Wife's , 2006 Chrysler Pacfica's low oil pressure light comes on when she is either slowing down or stopped, should i be concerned and how can i go about changing it?
Old Jan 11, 2021 | 08:09 PM
Try replacing the sending unit. Make sure the passage leading to it is not obstructed. If that doesn't fix the problem, get a gauge hooked up and check the actual oil pressure to make sure it's not actually low. Low oil pressure, if not corrected, can ruin the engine.
Old Jan 11, 2021 | 08:39 PM
brian3's Avatar
Mine was just the switch and was replaced. Not easy access so I had someone do it instead.
Old Jan 12, 2021 | 08:39 AM
FIREM's Avatar
FWIW Use only an OEM sending unit/switch. Have had issues more than once with aftermarket sensors.
stumpedmech
Sep 30, 2020 04:03 PM
Timothy Jones
Aug 26, 2020 07:49 AM
kenzenor
Nov 23, 2014 03:09 PM
paccar1
Jan 13, 2009 08:02 PM
cjsturgeon
Feb 18, 2008 04:18 PM
