Oil Pressure light
Try replacing the sending unit. Make sure the passage leading to it is not obstructed. If that doesn't fix the problem, get a gauge hooked up and check the actual oil pressure to make sure it's not actually low. Low oil pressure, if not corrected, can ruin the engine.
