P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
Old Feb 20, 2009 | 03:02 PM
alaskanJK's Avatar
Default P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
Ok so the car won't start,
I turned the key back and forth 3 times and it threw out this code P 0522
Which is "Engine Oil Pressure Sensor/Switch Circuit Low Voltage"
Could this be why it wont start?
Also I got an oil change the other day, could they have done something to cause this code?
Old Feb 20, 2009 | 07:49 PM
moe's Avatar
moe
what year? try disconnecting battery ,2 mins and reconnect.
Old Feb 6, 2021 | 09:00 AM
Bill Johnson's Avatar
I found this---------As with other error codes, this code triggers the Check Engine light and registers the code in the PCM. Other symptoms of Error Code P0522 include:
Engine may not start
Engine quits or stalls while in the middle of driving
Oil pressure gauge reading zero or low
Oil pressure indicator lamp illuminated
Possible Causes
There are many possible causes for this error code to appear; which include:
  • Faulty oil pressure sensor
  • Low oil level, blockage in the oil passage way or use of wrong oil
  • Open or short in the sensor circuit wiring
  • Bad connection, faulty connector in the oil pressure sensor circuit
corvairbob
Dec 18, 2017 08:51 PM
OGHBEICA8
Jun 20, 2012 10:44 PM
paccar1
Jan 13, 2009 08:02 PM
vettman
Aug 15, 2006 11:20 AM
