rear heater problem
Old Nov 3, 2011 | 03:11 PM
DKats's Avatar
Default rear heater problem
Now that cold weather is here, I've noticed that the rear passenger heater on my 2006 Pacifica is not working. The front heater, A/C, fans all work fine, its just the vent for the back seat doesn't work. The fan doesn't work but it feels like there is a tiny bit of cold air flowing out. I've seen some other posts about the blower module or resistor behind the glove box but that seems to cause problems with the main heater/fans in the driver and passenger vents, not the rear. I've checked all of the fuses. Any ideas would be appreciated.
Old Nov 3, 2011 | 03:21 PM
ok lets see if u can clear things up first do u have a hot/cold air issue in the back or do u not have any air flow from the back? Both are not related to each other so need to know which issue it is.
Old Nov 7, 2011 | 09:24 AM
DKats's Avatar
I guess the main problem is that there is no air flow
Old Nov 7, 2011 | 03:10 PM
check the blower motor and or the resistor for the back then
Old Nov 8, 2011 | 02:42 PM
DKats's Avatar
Is there a separate blower motor for the back? If so, where is it located? I know the main one is behind the glove box.
Old Nov 8, 2011 | 05:16 PM
oblivious there is a second one in the back u have a separate control for it right? ever heard of a fan running at 2 different speeds at the same time?
24 - Heating and Air Conditioning/Distribution, Rear/MOTOR, Blower/Removal
REMOVAL
Labor Operations: Click to display a list of Labor Operations associated with this procedure
NOTE: The rear blower motor and blower wheels are serviced only as a balanced unit. If either component is faulty or damaged, the entire blower motor and wheel assembly must be replaced.
1. Remove the front center floor console cover (Refer to 23 - Body/Interior/CONSOLE, Floor - Removal) .
2. Disconnect and isolate the negative battery cable.
3. Disconnect the body wire harness connectors from the rear blower motor power module and the rear mode door actuator Figure 1.
4. Remove the body wire harness bracket from the console support bracket.
5. Remove the eight screws and the two console support brackets from the floor console base and duct assembly
Figure 1 - Rear Blower Motor Housing
1 - SUPPORT BRACKET (FRONT)
2 - POWER MODULE
3 - SCREWS (8)
4 - SCREWS (4)
5 - REAR BLOWER MOTOR HOUSING
6 - REAR MODE DOOR ACTUATOR
7 - SUPPORT BRACKET (REAR)
6. Remove the four screws that secure the rear blower motor housing to the floor console base and duct assembly.
7. Remove the rear blower motor housing and place it on a bench.
8. Disconnect the rear blower motor wire harness connector from the power module.
9. Remove the eleven retaining clips and three screws that secure the housing together.
10. Carefully separate the two halves of the housing.
11. Remove the blower motor wire harness and grommet from the housing and remove the blower motor Figure 2.
Figure 2 - Rear Blower Motor
1 - REAR BLOWER MOTOR
2 - WIRE HARNESS GROMMET
3 - REAR BLOWER MOTOR HOUSING
4 - CENTER CONSOLE MODE DOORS
ryenke216
Aug 15, 2012 11:48 AM
neh218
64
Nov 28, 2011 03:54 PM
skywalker
Jan 22, 2011 08:19 AM
prsolar2001
Dec 5, 2009 04:29 PM
jerryls
Oct 1, 2007 06:13 PM
