Slipping trans
Old Jan 7, 2019 | 07:44 PM
Boneraq1's Avatar
Default Slipping trans
2005 chrysler pacifica touring transmission shudders when it tries to shift while driving on highway or around corners at times and when u punch it. Has 175k. Been a great car for 12 years. Trans fluid change at 140k
Going to change fluid n put in full synthetic with Lucas no slip oil. Thoughts. Better to put in rebuilt or get it rebuilt. AAMCO a good option for this or not.
Old Jan 7, 2019 | 11:29 PM
Barbara 2's Avatar
Was the pan off the last change time ? Ours was rebuilt with a very good shop but still had problems later. AAMCO can have a bad rap, but it depends on the shop boss no mater where. Really good AAMCO guy found our problem. Trans controller box up under drivers side wheel well was the problem. First, he worked on it for a while and was able to put pressure gages on it. Soon said "Why is it doing that" since he knew better. His knowledge led him on. Now he has retired from that shop but we will go back again to the same shop before long for service. I'll trust the new boss there until I know different. Hope others will chime in too. B2
Old Jan 8, 2019 | 02:32 AM
Taronga76's Avatar
You say the oil was changed at 140k on the transmission but was the filter changed at the same time as well?
Old Jan 12, 2019 | 07:48 PM
Ronald Jones's Avatar
Does the car make any unusual noises when you rev the engine? Does the engine also seem to lack power while driving up a grade?
rrolleston
Jul 7, 2016 11:45 AM
zach92
Feb 9, 2014 07:55 AM
jhuntsebring
Mar 1, 2009 10:33 PM
moe7404
Jul 20, 2007 10:15 PM
Tony24md
Dec 15, 2005 12:11 PM
