Transmission Leak
Old Oct 14, 2011 | 12:18 PM
cowli4nia1's Avatar
Default Transmission Leak
I was currious if anyone has experienced leaking transmission fluid for the cover that I highlighted? If not, does anyone know if I can just drop that pan and reseal?
Old Apr 6, 2013 | 11:25 AM
sorin1307's Avatar
Hi there,
I have the same problem? I just noticed last night, did you fix it? Is the seal or something else.
Thank you
S
Old Apr 6, 2013 | 06:21 PM
Djinn-n-Tonic's Avatar
A few things come to mind.......
Make sure the leak is NOT coming from the Axle seal housings,or the PTU joint. since fluid doesnt Leak in an UPWARD direction, it can be very easy to mistake a leak at the diff cover from fluid that has "Blown around From driving.
Next remove the cover and ensure the housing isnt cracked (Somewhat common)
The good news is.... If youre sure it is a cover leak, reseal it with RTV silicone and call it a day. There is no gasket available, and there never was, rtv was used from the factory.
Old Apr 12, 2013 | 01:25 AM
lilrobert1's Avatar
wont let me view pic ? sounds like same issue I have is your a front wheel drive
farmerbob02
Apr 13, 2011 12:04 AM
billbon8
Sep 1, 2008 12:49 PM
hammerdown72
Apr 5, 2008 07:10 PM
fyrepower
Nov 16, 2007 07:44 AM
Daryl Baines
Feb 25, 2007 04:38 PM
