trouble shooting trailer wiring harness
Old May 14, 2008 | 12:18 AM
georgeo's Avatar
Default trouble shooting trailer wiring harness
Hello All,
I am having a problem with a 2004 Pacifica trailer harness. The brake lights work on the vehicle but not at the plug. I am making the assumption that the harness combines the turn signals and stop lights. Any help would be appreciated.
georgeo
Old May 14, 2008 | 11:58 AM
Default RE: trouble shooting trailer wiring harness
did u use chryser wire harness or aftermarket one?
Old May 14, 2008 | 04:55 PM
Sierrasan's Avatar
ORIGINAL: georgeo
Hello All,
georgeo
The harness takes power directly from the power distribution box in the engine compartment not from the brakes/turn signals so they can work but they willnot trigger the trailer lights if the supply fuse is blown in the PDM. Check for a blown fuse #10.
Old May 14, 2008 | 09:14 PM
georgeo's Avatar
Yes sir, it's a Chrysler harness. The numbers on the tag read 82208221 and 23489A if that makes a difference. Using a test light, I get power for tail lights, one with constant power ( don't remember which one) and both turn signals but no brake.
georgeo
Old May 14, 2008 | 09:21 PM
georgeo's Avatar
ORIGINAL: Sierrasan
[/quote]
Hello Sierrasan,
Thanks for the tip , I'll check it in the mornig and report back.
georgeo
Old May 15, 2008 | 09:04 PM
georgeo's Avatar
Checked the number 10 fuse ( blue 20a) and it looked good and has continuity. Anything else I should check?
georgeo
AZ_Ron
Sep 16, 2012 07:07 PM
bettyboop
Apr 8, 2012 11:22 AM
spotmaticf
Jun 23, 2010 08:59 PM
rpdenney
Nov 18, 2008 04:24 PM
mrrbby
Apr 30, 2008 07:16 PM
