another camshaft position sensor question
Old Jan 31, 2009 | 09:50 PM
pixsmith's Avatar
Default another camshaft position sensor question
I was driving my 02 Cruiser yesterday when it died suddenly. It had a 340 code, and I have replaced the camshaft position sensor. Do I need to reset the PCM before the car might start? It hasn't started yet, but I didn't pull the battery for long when I changed out the sensor -- really less than 30 seconds to tell the truth, so the code is still in the memory.
Is there a visual check I can do to see if it is the timing belt? I have about 144K on the car, but this engine (I had a replacement put in about two years ago thanks to a defective head) has about 50K on it if that, and I am assuming that the belt was new when they put it in.
Thanks for any help. Of course this ahapepned at the most inconvenient possible time, but I was amazed at how easy the sensor replacement was. It's the only reachable part I have run into on this car!
Thanks,
Pix Smith
Arlington, TX
Old Feb 2, 2009 | 06:12 PM
The upper timing belt cover fasteners are pretty easy to remove. You can then eyeball the belt to make sure it's still there.
Old Feb 4, 2009 | 10:25 AM
pixsmith's Avatar
Thanks for the tip -- it was a broken timing belt. and I think I have been really lucky to find a great local mechanic shop less than a mile by my house.
Thanks for the help. This looks like a great resource.
Thanks again!
Pix
sumncguy
Apr 17, 2012 07:27 AM
jaek707
Dec 23, 2010 07:25 PM
manshack_one
Dec 13, 2010 06:59 PM
dcm1971
Oct 13, 2008 12:10 PM
jjmenard
Sep 6, 2007 05:33 PM
