No crank no start 02 pt cruiser.
Intermittent no crank no start. No pcm ground signal to both asd relay pin 86 ground circuit signal and starter relay pin 86 no pcm ground signal. Ignition switch replaced, starter and starter solenoid good. brand new battery. Bypassing asd works. Starter relay only works properly when asd relay is properly energized.
2001sebring2point7
May 9, 2015 12:22 AM
