No crank no start 02 pt cruiser.
Old Sep 7, 2021 | 11:13 PM
e82moore's Avatar
Default No crank no start 02 pt cruiser.
Intermittent no crank no start. No pcm ground signal to both asd relay pin 86 ground circuit signal and starter relay pin 86 no pcm ground signal. Ignition switch replaced, starter and starter solenoid good. brand new battery. Bypassing asd works. Starter relay only works properly when asd relay is properly energized.
Old Sep 8, 2021 | 09:16 PM
ggoose's Avatar
Check/clean the ground points on the left fender. Known problem area being close to the battery.
Jon Suponski
Jan 24, 2021 11:55 AM
Jo Close
Aug 20, 2018 08:57 PM
mgreenb561
Feb 28, 2018 06:12 AM
2001sebring2point7
May 9, 2015 12:22 AM
soxfan
Sep 20, 2008 11:11 PM
