01 t&c cranks no run
This one wont be easy 01 t&c 3.8 quit and no start dealer replaced pcm we have current info if i pay i want some good help because im good and can gather more info as needed. I dont have enough tech info to affect repair
ok here is what i have. 2002 town & country, 3.8. died while going down road. no spark...dealer had it a year never got it going. they installed a reman pcm and crank sensor. now i have inspected all related wiring, no chafing or obvious breaks. in another forum it recomended probing the ign coil lead for battery voltage at key on there was voltage, next it said to crank eng there should be voltage during crank. no voltage. asd relay swapped with like relay still no spark. replaced cam sensor, no spark. only codes in pcm are coolant temp sensor and mat sensor. i can provide more when given instructions on test
ty
Mod
ty
Mod
I did i asked u if there was a GROUND PULSE on the other wires at the coil when cranking. Not voltage but ground. The voltage comes from the asd relay then turns off when not trying to crank the engine.
