03 Town and Country cluster inop
Old Feb 27, 2014 | 11:08 PM
Hotrod89's Avatar
Default 03 Town and Country cluster inop
Hello and thanks for letting me ask the community for advice. I have a 2003 Chrysler Town and Country and my cluster is totally inop. I tried resetting it,checked all the fuses,disconnected the battery and checked for fault codes and none are present. Thanks very much and any help is most appreciated.
Old Feb 27, 2014 | 11:54 PM
remove the cluster and check for power and ground see whats missing on the wires.
Old Feb 28, 2014 | 02:17 PM
Hotrod89's Avatar
I removed the cluster and no power to the cluster and no power to the bar just above the cluster
Old Feb 28, 2014 | 06:01 PM
Raptor 07's Avatar
Do your flashers work? I've read of the feed wire to the flasher fuse severing itself due to corrosion. The same fuse feeds power to the cluster. In any case flip the IPM over and inspect for corrosion and broken wires.
Old Feb 28, 2014 | 06:39 PM
Hotrod89's Avatar
I checked the wiring under the ipm and nothing looks to be broken or corroded. I did take the cluster out and the the info bar thats just above the cluster and there is no power or ground going to either of those. Im not talking about the above console info center. Everything else works exceot for the cluster and the bar above it. I tried the self check but the cluster doesnt even come on or anything.
Old Feb 28, 2014 | 07:00 PM
Hotrod89's Avatar
I also checked the flashers and they are working as intended
Old Feb 28, 2014 | 11:23 PM
At cluster br/rd wire is hot all times C200 connector under the dash to go to the IPM under hood .
Hotrod89
Feb 27, 2014 10:27 PM
nov_284
Nov 6, 2012 12:20 PM
running_swift@hotmail.com
Aug 14, 2009 05:35 PM
cncstinson
Jan 12, 2008 08:34 PM
josh81
Dec 17, 2007 06:27 PM
