05 T&C Rear Liftgate works fine with everthing except manual door release switch
Hello All,
Been reading the threads on the T&C with lift gate problems but I didn't see one that matched mine so I was hoping to get a little guidance.
Problem:
Rear lift gate works using:
Can anybody help me put a nail in this?
TIA!
Ben
Problem:
- Key Fob
- Button on overhead console
- Using Key
- The black electric push button manual release (When pressed nothing happens no sounds what so ever)
- When any above working solutions works I hear the lock assembly click and it cinches up when the door closes so to my untrained eyes that appears to be working correctly
- There are two wires going to the switch...Green with Black and Green with Red. If I do a continuity test across those wires by piercing them or testing at the plug I have no continuity pressing or not pressing the button
- Tried to jump across those terminals and then found out it goes by resistance not power so found that test to do nothing for me
TIA!
Ben
Alan,
Thanks for the quick reply. From what I read online (After I tried to jump it) the system uses ground vs power and that inside the switch is a resistor and depending on the level of resistance on the circuit the lock should open or remain closed. I can't find any specs though so I don't know if that is
1. If what I've read is even true
2. What level of resistance my switch should read with the circuit open or closed.
Sorry John, I can't provide any further input. I've had a 2004 Voyager and my current model is a 2007. Neither have powered tailgate from the button under the licence plate lamp. That just releases the lock. Perhaps the Town & Country is different.
I'm sure other owners will join this discussion soon, this is a very active and very helpful forum.
Key in rear door lock, turn key, press button and lift door open manually. That's how door works manually with mine. Or press fob, or overhead consul buttons and it opens itself. That's if you've got electric doors that is.
Lovely when Merc owners try to show off with there electric rear door.. My side doors open as well, does yours...No...
Voyager is an underrated car by a long way.
I fixed this on my 03 grand voyager by taking off the panel above the number plate that houses the switch. Take the switch out by removing 2 tiny torx screws and sure enough water had got in and rusted the contacts. Clean, lube, and seal, put back together and all is still fine from nearly a year ago.
I refuse to buy new parts straight away. Especially electrical! Most can usually be rectified with minimal effort!
Mine works the same way as goggs' although I never use the key to unlock, I always unlock with the fob. I've never heard of a UK Voyager having the tailgate power switched by the local button, I didn't know that was a feature on some of them.
Just to close the loop on this one. It was indeed a faulty switch. As it turned out 2 of the clips that held it in were also broke so rather that take it apart and clean it up I just ended up replacing. Thank-you all for your feedback and help!
darkcild101
13
Jul 30, 2015 08:08 AM
deano6772
Feb 23, 2011 08:50 PM
MichaelB
Jan 17, 2011 12:38 PM
