'07 T&C ABS trac off lights on HELP!!!
Old Sep 9, 2011 | 08:30 PM
dartboy340's Avatar
Default '07 T&C ABS trac off lights on HELP!!!
'07 T&C ABS light on and traction control off light on in dash. No DTC's in any module. scan tool data
-brake switch closed
-LF 0 mph
-RF .42 mph
-pump 14.7v
-rr .42mph
-LR .42mph
-ref. voltage 0.0v
these readings are key on engine off. , driving the rf and rr are the only values that change and are accurate. now for the fun stuff. disconnect rf,rr,lr speed sensors and the reading only changes for the RF. connect the RF sensor and it reads as the RR. the rear wheels do not change any values in the scan tool. so, with all sensors hooked up, only the right side values change,
keep in mind that the LF shows change for the RF
and the RF shows change in the RR.
This is kicking my ***!! any help would be great!!
Thanks!!
Old Sep 10, 2011 | 03:02 PM
u need a batter scanner to get the real codes in the abs module
Nathaniel Karter Keith
Apr 6, 2015 06:58 AM
Dan400Man
Feb 5, 2013 11:35 AM
fragmented
Jan 24, 2013 03:03 PM
J Wikoff
Feb 24, 2012 11:08 PM
blong
Mar 31, 2008 10:15 AM
