09 T&C fwd evaporator and stall questions
Old Jul 2, 2017 | 01:21 PM
Ron Elberth's Avatar
Default 09 T&C fwd evaporator and stall questions
Hi folks I'm new to the Forum. I'm looking to buy a 09 Town and Country with a 3.8 and the 6-speed. The AC is out and the owner's girlfriend said she heard it hissing before it stopped working. I'm thinking the forward evaporator is probably bad. Anyone ever change one? Also anyone have advice on how I tell if this is one of the vans that has the stall issue? And was that ever corrected?
This man also has a slight noise coming from the rear that the owner thinks is the tires but my 05 Grand Caravan had the same noise which is now super bad and I'm sure is the wheel bearings. It's not a usual wheel bearing noise. Any thoughts?
This man has 174000 and the price is $2,800 which I think is pretty good unless it cost alot to fix the AC. It has stow and go
Old Jul 2, 2017 | 01:22 PM
Also I noticed the cruise control lever is installed upside down or it's the wrong one I don't know. The writing is upside down. It's on the left side of the steering column.
Old Jul 2, 2017 | 02:20 PM
Okay I was looking at a picture and now realized the cruise control spins with the steering wheel����
Anyone have a gander about the AC?
Old Jul 2, 2017 | 10:37 PM
georgef's Avatar
The weak point in the AC seems to be the rear evaporator. It is somewhat open to the elements and is located just behind the right rear tire where it can get splashed with water (and road salt if it is used in your area).
This video shows how the evaporator is replaced:
This video shows how to block off the rear portion of the A/C:
Old Jul 2, 2017 | 11:45 PM
georgef's Avatar
You can check to see if there are any open recalls by entering the VIN on this site: https://www.nhtsa.gov/recalls
xmanmta
Jan 21, 2016 04:37 AM
Gonorm
Oct 5, 2012 02:52 PM
tc_2004
Oct 7, 2009 10:56 PM
dcautowerks
Aug 29, 2009 09:03 AM
SueJ
Jun 22, 2009 10:15 AM
