1998 voyager
Old Oct 28, 2008 | 09:49 AM
beefy's Avatar
Default 1998 voyager
can anyone please help my 2.0 voyager battery warning light is on been told it is probably the power train control module any idea on how much these are new or can they be repaired and who does it thanx
Old Oct 28, 2008 | 11:08 AM
irdaneel's Avatar
Default RE: 1998 voyager
Unless there is a considerable amount of history involved here, it seems like a large step to replace a control module for a battery warning light. Did you have the battery checked/replaced? Did you have your alternator tested/replaced? Did you check all of your grounding wires off of the battery where they connect on the other end?
Yes, a Control Module could be the issue, but without looking elsewhere first it seems overkill to me.
Old Oct 28, 2008 | 07:53 PM
dodgetech1's Avatar
Deffinetly check your battery first make sure that its at 12.6 volts and the proper CCA i think they're rated at 600 CCA on those.
Hopefully your not one of the unlucky ones with the voltage regulator in the PCM. Always thought that was a stupid place for it.
Old Oct 30, 2008 | 02:11 PM
beefy's Avatar
YES I DID HAVE THE ALTERNATOR CHECKED AND THE REGULATOR IS IN THE PCM ONCE I PUT THE ALTERNATOR BACK ON AND RE-TENSIONED THE BELT I THE CHECKED THE VOLTAGE ACROSS THE BATTERY IT WAS 14.6 v GUESS IT MUST OF JUST BEEN A LOOSE BELT AFTER ALL
sonnyrol
Feb 9, 2007 07:38 PM
ibayter
Feb 5, 2007 11:11 AM
Brokenass
Jan 31, 2007 05:09 PM
RA1D3R
Aug 27, 2006 03:41 AM
allan1010
Jun 19, 2006 06:40 AM
