1999 gearbox leak (manual)
Old Oct 12, 2008 | 03:36 PM
dcm1971's Avatar
Default 1999 gearbox leak (manual)
is this common, and where is the possible place of leaking??
Hope you guys can help, just picked this car up (UK, 2.0LE, 5sp Manual) and don't particularly want a knackered gearbox!!
Old Oct 12, 2008 | 03:56 PM
dcm1971's Avatar
Default RE: 1999 gearbox leak (manual)
ok, just been out to look, and there was a big pool of oil on top of the gearbox, inboard to the clutch actuator, and I just can't work out where it could of come from.
Also, where is the gearbox top-up point?
Old Oct 13, 2008 | 02:52 AM
I wonder's Avatar
if you have an oil stain on top of the gearbox, that's NOT gearbox oil.
that's engine oil, and it can come from valve cover gasket, CAM sensor, EGR valve pipe, PCV hose on the intake air box.....
just in case, gearbox oil filling point is on the side. look behind front left wheel and you'll see the gearbox. side towards you, or the one facing forward, should have a plastic cork. remove the cork (unwind it) and check oil level. it should be up to the filling point.
remeber that this cars have engine oil in gearboxes. DO NOT put normal gearbox oil.
Old Oct 13, 2008 | 03:35 AM
dcm1971's Avatar
is there anywhere on the internet that will give drawn or picture images of the places it could be leaving, thanks.
Lushy
Dec 10, 2016 05:40 AM
lewisprime
Feb 10, 2016 09:31 AM
chrysler1
Feb 3, 2016 11:20 AM
andyeastsussex
May 5, 2015 11:57 AM
chrysler1
Dec 21, 2013 11:09 AM
