2.8 crd 2004 starting problem advice please
Old Dec 4, 2014 | 06:21 AM
mastiff's Avatar
Default 2.8 crd 2004 starting problem advice please
Hi all. I have a 2004 gv that will not start in the morning without easy start and even then only just. Last weekend i changed the fuel filter and housing ( tank bay ) the next morning it started fine but since then nothing. It blew the 20 amp fuel heater fuse i disconnected the heater on the pcv as its on the same circuit and it does not blow. Even when warm if i try to start her and wait umtil the fuel pump stops making any noise then she wont start any advice or suggestions would be greatly appreciated.
Old Dec 6, 2014 | 11:52 AM
fragmented's Avatar
Have a read through my starting thread - may help
https://www.chryslerforum.com/forum/...tarting-22405/
Old Dec 6, 2014 | 01:03 PM
tfb's Avatar
tfb
first thing is to do a "key dance" and check for fault codes. Search on here to find out how to do this.
Regards
Richard
Old Dec 9, 2014 | 06:01 AM
mastiff's Avatar
Hi Richard i got p0201 and p0403 i have changed the maf cleaned the egr and changed the copper washers on the injectors as 2 were leaking disconect the battery overnight but cant get the codes to clear no check engine light or limp mode. Not sure what to do now
Old Dec 9, 2014 | 07:55 AM
tfb's Avatar
tfb
the P0201 is an electrical fault with the injector no 1 and the 403 is an electrical fault with the EGR solenoid.
The codes will need to be cleared with a scan tool, where abouts are you in the country?
You need to confirm that the P0201 is not an active fault, then I'd start looking at fuel pressure and it's rise time
Regards
Richard
Old Dec 10, 2014 | 12:26 AM
mastiff's Avatar
Hi Richard thanks for the advise. Iam in essex. I have tried torque carista and scananator but the dont seem to work. Is there an app or cheap scantool people recommend
Old Dec 11, 2014 | 06:00 AM
tfb's Avatar
tfb
unfortunately there isn't a cheap scan tool that works on these engines.
I travel down the M11 most evenings and if you are not too far from there I can pop by and clear the faults and have a quick look
Regards
Richard
wasptim
Feb 3, 2023 12:41 AM
travelmad
Feb 2, 2013 03:58 PM
aprophet2
Jul 24, 2009 04:51 PM
musicfreak2195
Jun 3, 2009 08:43 PM
