2.8CRD stalling, cutting out under load
Old Feb 13, 2018 | 05:56 AM
  #31
One of dozens of LP side spin-on fuel filter posts from 6 years ago.
Now Andy's filter is different to mine but the cause + affect is exactly the same. The suction-side diesel fuel filter is always upstream from the tank and the fuel flows by vacuum through the filter as opposed to Andy's where the pump forces fuel under pressure, through the filter, so :
- loss of vacuum caused by air leaks
- air introduced into the fuel system could result in lower fuel delivery
- old + new 0 ring
- dry not lubed 0 ring
- slack [vibration] filter
- slack water drain tap
- dirty filter
- housing itself cracked
Busy garage, trainee does a service, radio on, gets distracted forgets to check 'nip up' tightness on filter can / water trap and all hell breaks loose.
Check the easy / cheap / DIY things 1st - hard expensive engineers later if you need to.
Duke Orr
Nov 30, 2014 09:03 PM
tksluke
17
Nov 7, 2012 09:00 AM
Neil O
Jan 13, 2012 06:29 PM
evansa uk
Sep 15, 2010 02:49 PM
actd
Apr 26, 2010 05:16 PM
