2.8CRD starts then stalls from cold!!!
Hi Guys,
As the title says, my 2.8 CRD will start from cold but then stalls after about 30 seconds. Then it is a real struggle to get it started again. When it does get going, everything seems perfectly normal.
Any suggestions will be much appreciated
Are you saying that you can start it from cold, but it never runs more than 30 seconds? And it will restart after you turn the ignition off for a while?
If so then it sounds a bit like a failed crank shaft position sensor. There should be a fault code if that is the case.
aaron1wii
Aug 26, 2014 01:05 PM
nikon70
Mar 1, 2013 03:31 AM
