2000 chrysler grand voyager LIMP MODE
Old Jun 17, 2013 | 03:24 PM
gearhead1's Avatar
Default 2000 chrysler grand voyager LIMP MODE
my 2000 Chrysler grand voyager went into limp mode, I changed the input and output sensors on the trans. it changed absolutely nothing! ANYONE have any suggestions for what to do next?
Old Jun 18, 2013 | 12:16 AM
how about get the codes from the trans mission computer and then let us know what they are
Old Jun 18, 2013 | 08:51 AM
If you are anywhere near tfb, he will do a proper 'deep' code[s] read for you.
Old Jun 18, 2013 | 01:22 PM
Raptor 07's Avatar
There are around 30 failures that can cause a van to go into limp mode. The in out sensors are just two - a cheap easy shot in the dark but a shot in the dark. You need the codes.
Old Jun 18, 2013 | 06:46 PM
I came across an 05 2.8 that goes into limp mode almost any / every journey, every day in winter and almost never, maybe once every 6 weeks in the summer.
Now that's conundrum, he still has it to this day, no one ever figured out why. If you have any ideas I'll pass them on.
Old Jun 20, 2013 | 03:32 AM
tfb's Avatar
tfb
I'm in Cambridgeshire, but I travel to London most evenings so if you are anywhere near that I can read the codes.
As others have said there are quite a lot of things that will cause limp mode.
You could also try doing the "key dance" trick - search these forums for it.
Regards
Ricahrd
Old Jun 20, 2013 | 08:54 AM
Do the 'key dance'
- its a different car but the same sequence
Put your hand on the key / on and then off and then on and then off and then on and leave it on
SO, 5 clicks - on-off-on-off-on and leave on
Even the best of UK garages won't have a 'deep reader' for this vehicle, only the main stealer @ £100 a pop.
NOTE : #23 for the 'marriage' of the (1) Sentry Key Immobilizer Module and the (2) 'codes Key Dance'
Old Jun 21, 2013 | 05:49 AM
tfb's Avatar
tfb
A DRBIII is the only tool that will read and do everything, StarScan and WiTech wont talk to these.
A few independents do have these, but not many. My X431 will read everything (or at least I haven't found a module it wont read) but no programming functions.
Regards
Richard
Old Jun 21, 2013 | 01:54 PM
Voyager Pilot's Avatar
My UK 2000 LX 3.3 Grand Voyager also went into limp mode....for me it turned out to be a failed solenoid (external module on bellhousing)....
Hope that gives you another avenue of thought....
brutus
Nov 20, 2019 07:02 PM
dinhle504
24
Jul 9, 2014 06:33 AM
ouhogfan
Jun 12, 2012 11:38 AM
nanu73bear
Sep 24, 2007 12:31 PM
luellajean
Aug 8, 2007 07:29 PM
