2000 t&c 3.8
Old Jun 1, 2012 | 04:53 PM
dwsracing's Avatar
Default 2000 t&c 3.8
My van always fired right up on first hit of the key. The fuel pump went bad, replaced pump and gas filter. Now it takes 3 or 4 times to start when cold. Seems ok when hot. Did a fuel pressure test and seems great but not to familiar with fuel injection, yet lol. Any ideas or things I am missing on this issue, thanks.
Old Jun 1, 2012 | 09:24 PM
put the fuel pressure on the port and turn it over watch to see where it stops should be 55 then walk away for a few hours come back then see if the pressure has dropped down below 40 or something like that
Old Jun 2, 2012 | 08:21 AM
dwsracing's Avatar
I did check, it was at 55. But it dropped fast to 19.
Old Jun 2, 2012 | 01:28 PM
the fuel pump either has a bad check valve or something like that
Old Jun 2, 2012 | 02:28 PM
dwsracing's Avatar
Well after thinking, it most likely is fuel pump related, that is what was changed.
Old Jun 2, 2012 | 09:13 PM
maybe the parts u are getting does not have the check valve in it I have no idea
Old Jun 3, 2012 | 06:18 PM
dwsracing's Avatar
I think this is the one I got, will double check Buy Airtex Fuel Pump Module Assembly E7094M at Advance Auto Parts Hoping they will replace it for me. My son works there so with alittle luck.
Old Jun 10, 2012 | 09:44 AM
dwsracing's Avatar
Update, It was a bad pump. Replaced and starts as it should now. Thanks for all the help, this form Rocks !!!
Old Jun 10, 2012 | 11:34 AM
welcome
Old Jun 10, 2012 | 07:01 PM
TNtech's Avatar
If your son works at a parts store, see if they can get discount Mopar parts from the dealer. I know it works the same for us >>> the other way around.
DRFUZZ
Jan 6, 2010 10:19 AM
ladyas
Dec 13, 2009 06:09 PM
d3aglewhor3
May 5, 2009 12:58 AM
chryslervan
Mar 21, 2009 10:07 PM
chryslervan
Mar 16, 2009 07:02 PM
