2001 rear power hatch problem
Old Aug 20, 2007 | 08:48 AM
davet's Avatar
Default 2001 rear power hatch problem
My 2001 has a power rear hatch that willunlatch witha push of the button but will not continue to go up. I have gotten it to work a few times after I've manually unlocked the hatch with the key. It worked15 times in a row where the door would go up and down automatically but then I started it and after shutting it off it stopped working. It will always unlatch automatically (lift approx 1") but wont raise the door. Any ideas? thanks.
Old Aug 20, 2007 | 04:10 PM
Default RE: 2001 rear power hatch problem
i see the rear hatch latch most of the time the issue but with out knowing the codes that the hatch computer says i cant say for sure.
Old Aug 20, 2007 | 04:32 PM
davet's Avatar
You mean the latch assembly in the hatch or do you meanthe sensor mounted to the latch? Is there a way for me to get the codes myself. I know my generic scan tool shows nothing. What would the dealership charge to check for codes on that latch? Thanks for all the help here.
Old Oct 25, 2007 | 01:10 PM
pittstategorilla97's Avatar
My '02 is doing the same with the rear hatch. Do I need to replace the latch mechanism? The door will start to open, then it just seems that the latch will not disengage and allow the hatch to continue opening.
Old Oct 25, 2007 | 01:39 PM
moe's Avatar
moe
HERE IS A TSB THAT APPLIES TO YOUR PROBLEM I WOULD TAKE A COPY OF THIS TO YOUR DEALER SEE IF WILL APPLIES TO YOURCAR SINCE I DON'T KNOW YOUR VIN. "MOE"THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-035-00
REV. A, DATED OCT. 27, 2000, WHICH SHOULD BE REMOVED FROM
YOUR FILES. THIS IS A COMPLETE REVISION AND NO **ASTERISKS**
HAVE BEEN USED TO HIGHLIGHT CHANGES.
SUBJECT:
Power Mode Closes Lift Gate But Does Not Open The Lift Gate
NOTE: THIS BULLETIN SHOULD BE PERFORMED ON ALL IN STOCK VEHICLES
BUILT BEFORE NOVEMBER 13, 2000 (MDH1113XX).
OVERVIEW:
This bulletin involves flashing the Power Lift Gate (PLG) module and resetting
obstacle detection values. Adjusting the lift gate striker and/or installing lift
gate overslam bumper shims may also be required.
MODELS:
2001 (RS) Town & Country/Caravan/Voyager
2001 (RG) Chrysler Voyager (International
Old Oct 26, 2007 | 11:27 PM
master tech's Avatar
Most of the time the latch assy is the cause for the power liftgate not to open. I am also seeing the same problem with the aspen too.
boise_chief
Feb 28, 2011 08:16 PM
sdwhitney
9
Sep 22, 2009 06:10 AM
marianne
May 17, 2009 11:30 PM
user440
Dec 15, 2008 07:18 PM
DFB
Feb 12, 2008 11:01 PM
