2002 Chrysler Voyager
Old Nov 15, 2009 | 06:13 PM
MilkMan's Avatar
Unhappy 2002 Chrysler Voyager
I have a 2002 Chrysler Voyager 2.4 liter.
I am getting codes of P0442,P0455 AND P0301.
It has been running rough and missing out. I know what the codes translate to but the translations are vague.
I have changed the plug wires and the plugs. I changed the temp sensor.
I have crawled all over the van looking for loose wires or vacuum leaks
but i can`t find the problem. I am hoping that there is an easy fix to this problem since i do my own maintenance.
Thank you in advance for any suggestions.
Old Nov 15, 2009 | 07:15 PM
22chrysler's Avatar
compression test?
P0442 nothing to do with misfire: it's evap problem with a medium leak
P0455 nothing to do with misfire: it's evap with large leak (gas cap)
p0301 misfire #1 which is where your problem lies. could be compression (rings, valves) could be a worn cam lobe, could be bad injector and much more
kkc
38
Mar 15, 2016 07:52 PM
Smalley1980
Jul 19, 2015 05:53 PM
Edward Smalley
Jul 5, 2015 09:39 AM
nicowagon
Feb 7, 2014 03:50 PM
jaonajh
Mar 12, 2010 08:34 AM
