2002 Chrysler Voyager LX
Old Jul 17, 2015 | 03:35 PM
Smalley1980's Avatar
Question 2002 Chrysler Voyager LX
I found two error codes on my van today, they are P0700 and P0732, I replaced the inpourt and out port speed senoors and the
Shift Solenoid. it did not fix the problem with no revser or loss of power when rpms jump up while in drive so I can shut down and restart to go a head but it does it over and over again. what should I look at next to try to fix my van the fastest way possible
Old Jul 19, 2015 | 01:46 AM
tfb's Avatar
tfb
Fastest possible way would be to replace the gearbox.
Though I would recommend that you change the fluid and filter first and then have the codes read.
P0732 is a code raised when it reads the wrong input/output ratio for 2nd gear.
Regards
Richard
Old Jul 19, 2015 | 10:46 AM
what is the gear box located i have replaced both output and input speed sensors and changeing the fluid and filter and the TCM is the next thing im going to do
Old Jul 19, 2015 | 03:15 PM
Can't see anything relating to engine in your car, so if its petrol check for toasted wiring.
Old Jul 19, 2015 | 05:53 PM
the engine in my van is a 3.3 V6
kkc
38
Mar 15, 2016 07:52 PM
Edward Smalley
Jul 5, 2015 09:39 AM
nicowagon
Feb 7, 2014 03:50 PM
jaonajh
Mar 12, 2010 08:34 AM
MilkMan
Nov 15, 2009 07:15 PM
