Chrysler Voyager 2.5 diesel weird starting problem
Old Nov 15, 2009 | 02:15 PM
tramline's Avatar
Default Chrysler Voyager 2.5 diesel weird starting problem
Hi I wonder if anyone can help me with a weird problem I am having with my Chrysler grand voyager limited 2.5 diesel 2002 model...?
The engine will not start once it has been left over night like from cold, it just turn over and over till the battery goes flat...first off I thought glow plug or relay failed...I have tested the relay and changed the glow plugs and tested all connections showing they work and glow red at ignition as should do, so I am lost for answers...
Now for what I do to get the car to start... I put boiling water on the fuel rail and pipes and injectors area... then turn the car over which then start the car instantly as nothing wrong...the car run perfectly from then on with no loss of power or lumpiness’/misfire or any other definition of something being wrong with the engine...also for the rest of the day it will start with ease as I suppose the heat is still in the engine...there are no fault codes being registered either...
Please could anyone explain what possibly be the fault with this engine starting problem...?
Thanks Mark
Old Nov 16, 2009 | 03:05 PM
Merlin's Avatar
Have never heard that before. Can't believe the water would make that much of a difference. First test I would do is the see what the fuel pressure is reading in the ECM if you fault code reader can read fuel pressure.
Blackadder
13
Oct 7, 2013 06:17 AM
ktrent
Mar 30, 2012 06:33 PM
mathiaskt
Apr 17, 2010 04:47 AM
donnyohs
22
Jul 17, 2009 03:19 PM
thepeel
Aug 11, 2008 01:12 PM
