2003 Chrysler town and country
Old May 25, 2012 | 05:42 PM
Rnbuck01's Avatar
The terminal I touched is 86, is that the ground coming out of the PCM?
Old May 25, 2012 | 05:59 PM
Rnbuck01's Avatar
What could be my problem? I have power on 30 and 85 and 86 when the key is off. I jumped the sensor on the expansion valve , and have tested the pressure switch for 5 volts and jumped the terminal.
Old May 25, 2012 | 06:17 PM
Rnbuck01's Avatar
What could be my problem? I have tested for power at 30 and 85 and 86 and they have power when the keys on. The pressure señor has 5 volts and jumped it and it still doesn't kick on the sensor on expansion valve is good. I jumped it and it still doesnt turn until I probe the terminal with my test light. Does the ambient temp sensor have anything to do with the ac system?
Old May 26, 2012 | 12:25 PM
Rnbuck01's Avatar
Had errors in last post.
What could be my problem? I have tested for power at 30 and 85 and 86 and they have power when the key on. The pressure señor has 5 volts and jumped it and it still doesn't kick on. The sensor on expansion valve is good. I jumped it and it still doesnt turn until I probe the terminal with my test light. Does the ambient temp sensor have anything to do with the ac system?
Old May 26, 2012 | 01:28 PM
  #15
TNtech's Avatar
The pressure transducer is not an ON/OFF switch. The resistance value is calculated by the PCM as a pressure value. So jumping scross it will do you no good. Yes, the ambient temp sensor comes into play. If the PCM thinks that it's 40 below zero (which I think is the open circuit value) it will not engage the clutch.
treverandamber
Feb 22, 2017 01:47 PM
xdm
Jan 21, 2011 05:41 PM
CML
Jun 20, 2010 04:30 AM
AndyM
Feb 19, 2010 11:03 PM
roy.rut
Nov 1, 2009 07:30 AM
