2003 Chrysler town and country
What could be my problem? I have tested for power at 30 and 85 and 86 and they have power when the keys on. The pressure señor has 5 volts and jumped it and it still doesn't kick on the sensor on expansion valve is good. I jumped it and it still doesnt turn until I probe the terminal with my test light. Does the ambient temp sensor have anything to do with the ac system?
Had errors in last post.
What could be my problem? I have tested for power at 30 and 85 and 86 and they have power when the key on. The pressure señor has 5 volts and jumped it and it still doesn't kick on. The sensor on expansion valve is good. I jumped it and it still doesnt turn until I probe the terminal with my test light. Does the ambient temp sensor have anything to do with the ac system?
The pressure transducer is not an ON/OFF switch. The resistance value is calculated by the PCM as a pressure value. So jumping scross it will do you no good. Yes, the ambient temp sensor comes into play. If the PCM thinks that it's 40 below zero (which I think is the open circuit value) it will not engage the clutch.
treverandamber
Feb 22, 2017 01:47 PM
CML
Jun 20, 2010 04:30 AM
AndyM
Feb 19, 2010 11:03 PM
roy.rut
Nov 1, 2009 07:30 AM
