2003 voyager WON'T START
Old Jan 15, 2012 | 06:34 AM
caolan's Avatar
Default 2003 voyager WON'T START
HI ALL, Our 2003 voyager 2.5 D, Won't start when you clutch it but will start on a jump, the clutch is sliping a bit would this be the cause ??
Old Jan 15, 2012 | 08:14 AM
booke23's Avatar
By clutching it I assume you mean pushing/towing the car up to about 10 mph putting it in 2nd gear and letting the clutch out. If so most modern cars won't start by by this method.
The ecu won't inject fuel until it detects the starter being activated and the crank shaft position sensor detects at least one revolution of the engine.
Old Jan 15, 2012 | 10:29 AM
caolan's Avatar
you have to push the clutch in to start the car and when i clutch it it wont start, but i rolled it and it jumped started
Old Jan 16, 2012 | 12:49 AM
kdm3170's Avatar
1 of the clutch switches may have gone bad or the connectors have come loose. theres a clutch pedal interlock switch and a clutch pedal upstop switch. i assume both conenctors are just 2 pins, disconnect the connectors and check for continuity with the switch in/out
[IMG] Uploaded with ImageShack.us[/IMG]
Old Jan 16, 2012 | 08:52 AM
caolan's Avatar
thatk's for the reply,ibut can't see were this is located is there another photo?
[IMG] Uploaded with ImageShack.us[/IMG][/quote]
Old Jan 16, 2012 | 10:57 AM
kdm3170's Avatar
its attached to the bracket the clutch pedal is attached to, take off the trim panel under the steering wheel and the panel behind that.
Old Jan 17, 2012 | 02:16 PM
booke23's Avatar
Sorry, I got the wrong end of the stick.....I didn't know you have to push the clutch in on the manual to start it as mine's an auto.
The switch on the pedal sounds like its worth checking.
Old Jan 17, 2012 | 05:35 PM
pestilance's Avatar
switch on pedal will prob have function for the cruise controll to.
Old Jan 20, 2012 | 02:35 PM
caolan's Avatar
thanks so much for the replys, turns out to be the STARTER so again thanks
nottmtrucker
Dec 1, 2019 02:45 PM
kurt40
Jan 8, 2015 02:00 PM
clsals
Jul 15, 2011 09:21 AM
jasone6789
Jan 7, 2011 11:52 AM
possumfat
Oct 17, 2007 08:35 PM
