2005 2.5d voyager reverse lights not working
Old Jul 11, 2013 | 05:32 AM
Nicko's Avatar
Default 2005 2.5d voyager reverse lights not working
hi folks i have a voyager manual gear box and i think the reverse light switch on the gearbox may be faulty, does this sound like a likely faul? i dont think both bulbs have gone... maybe a fuse?
Old Jul 14, 2013 | 03:27 AM
Nicko's Avatar
Any ideas?
Old Jul 14, 2013 | 04:36 PM
Nicko's Avatar
Anyone know if there is a seperate fuse for the reverse lights?
Old Jul 14, 2013 | 05:13 PM
tfb's Avatar
tfb
there is a reversing light switch on the gearbox, page from the manual attached.
I cant find a wiring diagram specific to a manual gearbox but from looking at the wiring diagrams it seems things aren't as simple as they used to be. The reversing light is fed from the Body Control Module - Connector C2, Pin9 White/ Light Green wire. Where the BCM gets the signal that you are in reverse is not shown for a manual car - for an auto box it's a data message from the gearbox ECU.
Testing the reversing light switch should be easy once you get underneath, just use a multimeter to test for a change in continuity bewteen the two terminals as you change in and out of reverse.
Regards
Richard
Attached Thumbnails 2005 2.5d voyager reverse lights not working-reversing-light-switch.jpg
Old Jul 15, 2013 | 04:37 AM
Nicko's Avatar
thanks ,just what i was looking for.
xjr41
24
Oct 13, 2015 02:12 PM
DanNotTheMan
Sep 28, 2012 09:15 AM
dueceduece22
Feb 21, 2012 06:31 AM
we51ham
Oct 20, 2009 03:23 PM
