2005 Town& country Brakes making noise
Old May 22, 2007 | 03:56 PM
drlisz's Avatar
Default 2005 Town& country Brakes making noise
2005 Town and country 31000 miles, Noise coming from left rear wheel when hiting bumps on road sounds like a loose fender but its quiet when the brake is applied. so i would imagine 1 of the shoes is loose, at this mileage should the rotors be turned down or replaced or left alone, they look or should get new pads and let them go no squeak from rotors brakes feel good LOOSE PAD PISSING OFF MY WIFE, guess who gets yelled at, Thanks everyone.
Old May 22, 2007 | 04:39 PM
Default RE: 2005 Town& country Brakes making noise
31k U dont want to replace one set of pads u will have a brake pull unequal of brake power being applied one will grab better as well. Turn the rotors and replace the pads. There is no drum brakes on mini vans any more =) all disk. What makes brakes make noise is when they are applied the pad moves in the caliper assembly and rubbs on the caliper bracket. This is why they have aiti squeel plates on the outside of them. Low pad will decrease the distance the anti squeel shim makes contact with the caliper bracket.
Old May 22, 2007 | 06:56 PM
drlisz's Avatar
Thanks Chrysler Tech, i will do both sides, but the noise is not from the clip on the pad i believe its from pad being loose in the caliper, I,m not sure what pads do you recomend cermaic, or something else.
Old May 22, 2007 | 11:17 PM
your choice I use mopar v line 65 bucks
Old Jun 7, 2007 | 02:02 AM
bartley's Avatar
Never reinstall worn brake components of any kind. I would suggest installing new chrysler brake pads onto the caliper. It's also a good idea to use a high-qualitybrakefluid. A better fluid will have a higher boiling temperature and will be more resistant to fade.
revraginsebring
May 20, 2014 06:31 PM
97_chrysler_lhs
Nov 20, 2012 08:58 AM
Darren79
Feb 6, 2011 11:42 AM
kristiruman
Jun 25, 2010 02:11 PM
13ducati13
Sep 1, 2006 09:29 PM
