2013 T&C Remote Start Modify
Old Jan 20, 2016 | 07:41 PM
cahanson@new.rr.com's Avatar
Post 2013 T&C Remote Start Modify
Does anyone know if the remote start items auto turned on can be modified? When I remote start the van, the heated seats, steering wheel, defrost and rear defrost all turn on at the start of the engine. This is a pretty big load and with these colder temps, the belt squeals for the first half of minute. I'm sure that it is aging the belt. If I start it normally by hand, all that stuff stays off except for the heater if it was left in auto from the last time. Is there a way to set what I need for these auxiliary items during a remote start sequence. Obviously, in the summer it must change to some other sequence as you won't need heated seat on. Any insight would be appreciated.
Old Jan 21, 2016 | 08:58 AM
ChryslerCares's Avatar
On models that are equipped with remote start, the heated steering wheel and heated seat functions can be programmed to come on during a remote start. Refer to “Remote Starting System — If Equipped” in “Things to Know Before Starting Your Vehicle” for further information.
Old Jan 21, 2016 | 09:15 AM
Read your book of destructions.
Old Jan 21, 2016 | 09:17 AM
Post
I looked and re-read the user manual from page 30 on in the "Remote Starting System - if equipped and it does not talk at all about programming the seat and steering wheel heaters to come on on a remote start. There seems like it would have to have a programming option somewhere based on the extras that come with certain models. Do I have to take it to a dealer to have the options changed?
Old Jan 21, 2016 | 03:35 PM
georgef's Avatar
The heated seats and steering wheel with remote start can be disabled using the EVIC (Electronic Vehicle Information Center). The instruction are on page 349 of the manual that QinteQ linked to in his post above.
From the manual:
Remote Start Comfort Sys.
When this feature is selected and the remote start is activated, the heated steering wheel and driver heated seat features will automatically turn on in cold weather. These features will stay on through the duration of remote start or until the key is turned to RUN. To make your selection, press and release the SELECT button until a check-mark appears next to the feature showing the system has been activated or the check-mark is removed showing the system has been deactivated.
If your van doesn't have the EVIC you may be able to have the Dealer program it for you.
Old Jan 21, 2016 | 06:22 PM
Post
Thank you, That setting was hidden pretty good and there was no reference in the remote start info. I was able to get to it pretty easily and turned off the comfort system to see if that makes a difference. In the end, I'll probably end up replacing the serpentine belt so that it doesn't squeal at startup. Again, Thanks, I appreciate the quick help.
Old Jan 23, 2016 | 05:35 PM
flyingpostman's Avatar
I have a 2015 T&C with remote start and power doors and looking under the hood for the first time I was surprised at how large the battery is. Is it the same size battery for all the models?
Old Feb 26, 2016 | 05:27 AM
s.m.'s Avatar
Yes, all models have the same (small) battery. I have changed this and use a 100Ah battery
stubarnes4141
Nov 20, 2015 07:54 PM
hmhill17
Jan 14, 2015 08:53 AM
Butchiem1
Jun 13, 2013 08:46 AM
hoopsnut
Jan 8, 2013 04:17 PM
sponnerjhon
May 30, 2012 07:22 PM
