97 chrysler town & country steering wheel shakes!! help!!
Old May 20, 2009 | 04:11 PM
djcproject's Avatar
Red face 97 chrysler town & country steering wheel shakes!! help!!
Hi there!!
I have a 97 town & country lxi 6cyl fwd/ now this is the problem! For some reason the steering wheel shakes a lot and a wobble it feel in the front end when start moving a slow speed! Well it happening even at a faster speed now it getting worst and worst and it's like it coming from the front driver side it's like if it was one of the tire gone bad. But now i had change the tires, the driver and passenger side axles ,driver side hub with bearing and both sides brake rotors! And done wheel alignment, and still the same problem. There's nothing else i can think of that it can be. Some one suggested that it may be the motor mount that may not be center and it can cause the axle to go out of place this thing is driving me crazy. Any one have any suggestion? Help please!!
Old May 20, 2009 | 05:07 PM
mrfixit454's Avatar
How about tie rod ends? New tires were balanced right? Not sure if the car has ball joints on the bottom or not.
Old May 21, 2009 | 09:39 AM
djcproject's Avatar
Thanks for replying!! I may have to check on the tie rods inner and outer see if that solve my problem hope it does. and yes the tires were balanced when I purchased them. the weir thing is that I can feel a wobble in the front end, like one of the tires is bad well it feel like it coming front the driver side.
Old May 21, 2009 | 10:53 AM
u got cheap tires its called low speed tire wobble.
Old May 21, 2009 | 11:02 AM
djcproject's Avatar
but the problem started long before I changed the tires, I started with the tires because I thought that was the problem but since It didn't fix anything I proceeded to replace other part! as I mentioned. thanks
Old May 21, 2009 | 09:51 PM
then bad rim
Old May 25, 2009 | 08:48 AM
djcproject's Avatar
FOLLOW UP!!
I finally changed the Tie-rod ends inner and outer on both sides, the ball join on driver side, the sway bay link on both sides,and the shocks and both side and Thanks God the problem is gone now. I noticed that when I took the Inner Tie-rod they were real bad, so thanks guys for your suggestions and ideal. thanks!!
Old Feb 21, 2011 | 01:36 PM
TomRodgers's Avatar
Default Tie Rod replacement...
I have a 2000 Grand Caravan Sport (yeah...right)...The inner tie rod is suspect in the following: grab drivers side wheel at "9" and "3" and move left and right (in and out) and there is play. Outer rod replaced (was in SUPER bad shape). problem still exists. no play on passenger side. how much of a PITA is it to swap the inner rod? any tricks or tips??? Thanks!!!!
Victor L
Jan 12, 2014 08:38 AM
vajrus
Nov 20, 2013 03:43 AM
10Miler
Mar 22, 2013 06:13 AM
wv53
Aug 30, 2011 03:54 AM
tk1780
9
Oct 30, 2007 10:39 AM
