98 T&C #1 plug fouling and missing out.
1998 Chrysler Town & Country Question: Missing out, and fouling on #1 plug. Never used oil before, but has used 1 1/4 Qts. In the last 1700 miles. Pretty sure it's a ring issue, but it was running fine before. This came on suddenly during a long trip. Only missing out below 3k rpm.
You could have a "stuck ring" rather than a broken one. Get the piston halfway up the bore and pour in some penetrating oil through the spark plug hole and leave overnight. You shouldn't need more than a small egg-cup full. After the overnight soak, crank it with the plugs out, that should help, and blow out any penetrating oil too before replacing plugs and testing.
Won't cost much in time etc., and might save an expensive stripdown. I'd rate a 30% chance here.
Leedsman.
Leedsman.
Leedsman.
Leedsman.
Wish me luck!
ScooterKat
P.S. I'll let you both know how it worked out when completed.
We changed the oil and air filter about 2 weeks ago, and made sure everything was working and fluids were topped off. Then we made our trip from Indiana to Phoenix. Along the way we checked fluids at every other fill up and everything was great. Except we did get a little overheated in Oklahoma, not bad, just hotter than normal. We topped of the coolant because it was low and everything was fine after.
Van made it through the mountains fine and ran like a dream until we hit Phoenix. Once we hit lower speeds(40 and below) is when we noticed it missing out and running rough.
Once I saw the fouled plug after replacing the first one my heart sank. Really hoping and praying that his hint fixes it.
Take care, and thanks again for taking time to reply.
ScooterKat
Hey Leedsman, I was wondering if you had any ideas other than a timing light on how to tell piston position in the cylinder? Not sure how to tell when it's halfway up without a timing light, and we don't have one on hand here. If that's the only way I'll have to borrow on, or see if the parts store has a loner.(highly doubtful)
Thanks for your help,
ScooterKat
ScooterKat
If the engine is so designed, popping a thin metal rod down the plug-hole might indicate the piston half-way point as you turn the engine by hand, all plugs out. Fingers XXed. It doesn't have to be exact BTW., it should even work ok near the top or bottom (top is better because the way the cylinder wears) -- you just need enough room for the the penetrating oil.
After the overnight soak, try and work the engine back and forth a little by hand; this might help free any part which is stuck too.
Leedsman.
Leedsman.
emhomes
Jan 19, 2014 05:42 AM
davidplans
Sep 25, 2010 08:39 PM
strange everytime i plug the plug into the sensor on my coolant water outlet my radiator fan stops..
musicfreak2195
Feb 12, 2009 03:17 PM
