99 t&c brake light issue help please
Old Apr 12, 2015 | 02:42 PM
jeffmwv's Avatar
Default 99 t&c brake light issue help please
Ive got a 99t&c limited. The brake lights work fine but if i turn on the headlights the brake lights stay on constant. I checked the fuses under the dash and replaced the brake light switch also. Any suggestions where to look next would be great. Thanks
Old Apr 12, 2015 | 04:04 PM
royal100805's Avatar
The tail lights and brake lights run through the same bulb in the rear lights. I think you should check the rear light circuitry to make sure you havent got a short between the tail & brake. Also remove the rear light assemblies and see if the circuit board or connections need a clean.
monsterdub
May 5, 2024 11:10 AM
4everrunning
Jun 4, 2019 11:30 AM
bgeise
Sep 12, 2014 10:38 AM
mattc01
9
Jul 25, 2011 06:30 AM
VanJockey
Mar 30, 2008 10:09 AM
