99 T&C (LHD US IMPORT) 3.8l Front Blower only works on high speed!
Old Nov 7, 2009 | 06:33 AM
dm6174's Avatar
Default 99 T&C (LHD US IMPORT) 3.8l Front Blower only works on high speed!
Hi Folks,
I am new here and have a minor problem that is majorly annoying!
I have a 99 LHD T&C that we imported from the US a few years back that has been absolutely fine until now.
The front blower now only works on the highest speed setting and I donīt know why!
If it helps anyone, it does not have auto climate control, it is just the two sliders.
Hopefully someone will have some ideas as to how I can try to sort this.
Dean
Old Nov 7, 2009 | 06:57 PM
22chrysler's Avatar
Originally Posted by dm6174
Hi Folks,
Dean
You have several repair options.
1: take it to a professional shop and have it professionally fixed
2: Get a wiring diagram and a multimeter and do your own diagnostics
3: start throwing parts at it hoping to fix it
4: just guessing, since I have seen numerous failures exactly like this, probably needs a new resistor block and/or connector.
Old Nov 7, 2009 | 08:58 PM
shawnsdad's Avatar
I would guess it needs a new resistor block. under 50 bucks and easy to do
Old Nov 7, 2009 | 09:44 PM
22chrysler's Avatar
so why dont you tell the man where this part is and how to replace it?
Old Nov 11, 2009 | 04:49 PM
billbon8's Avatar
Default Blower resistor
Hello,
I concur with the other recommendation to replace the blower resistor. Your symptom is a classic case of resistor burn out. I had the same thing happen on my 01 Concorde. I would get the Haynes manual to locate the part. It's probably up under the dash on the passenger side, held in with two screws and 1 wire connector. You should be able to see it from the passenger footwell. A little awkward to get to but only takes 20 minutes to remove and replace. Search the new part on Ebay, that's where I got mine. Good luck...Bill
Old Nov 11, 2009 | 05:39 PM
22chrysler's Avatar
Originally Posted by billbon8
Hello,
Good imput Bill.
but on the vans of this year, the resistor block is under the hood on the firewall near the alternator
rye2
Aug 31, 2012 09:31 AM
esu
Jun 14, 2012 12:44 PM
courtney frias
Apr 13, 2012 11:15 PM
marshlk
Jan 3, 2009 03:34 PM
jesuslike
Jul 26, 2006 04:46 PM
