ABS Light problem
Old Jul 16, 2012 | 02:40 PM
PADDY's Avatar
Default ABS Light problem
Hi - 2002 Grand Voyager 2.5 Diesel, ABS light has come on, it went out when I stopped & re-started the engine which then resulted in only about 10% braking efficiency, the car pulled to the right & it sounded like the ABS cut in about 25 meters later the ABS light came back on & the brakes worked fine. Any one got any clues to what the problem might be ?.
Old Jul 16, 2012 | 06:31 PM
- starting point is what you can yourself do Pat
- most times its a plastic covered sensor on one of the wheels, usually the front
- pull the wheel do a physical look - it only takes 5 minutes and a grain of sand @ 70MPH to make it look like a badgers arras
- the other one is rust on and between the counting teeth on the outer joint
If its not a sensor it gets complicated
- start by typing '''abs sensor''' in the search box top right of the page and reading what others have thought !
jimmy154
Dec 14, 2019 09:45 PM
ToddShroats
Feb 5, 2012 06:41 PM
mario65
Jun 3, 2008 08:27 PM
notVERYpleased
Jul 24, 2007 10:19 AM
chrysler34
Mar 18, 2007 03:33 PM
