ABS LIGHT AND TRAC CONTROL
Old Oct 1, 2008 | 07:55 PM
billbon8's Avatar
Default ABS LIGHT AND TRAC CONTROL
Hello,
I havean '05 T&C with40K miles. Today, the ABS light and traction control off light came on and won't reset. This happened once about a year ago, but I thought it was due to over-heating as it was 100 degrees.At that time, the dealer found nothing wrong. Any idea what could be causing this issue? Thanks!
Old Oct 1, 2008 | 09:12 PM
vwomein's Avatar
Default RE: ABS LIGHT AND TRAC CONTROL
those 2 systems both use the same parts(wheel speed sensors at each wheel). I'd guess that
one of the wheel sensors(ABS sensors) is bad, or the wire is loose or cut. Should be an easy & not too expensive fix. A computer scan should show which wheel sensoris the problem
Old Oct 5, 2008 | 07:18 PM
billbon8's Avatar
You were right. At the passenger side rear wheel, the cable was pinched between the brake line and the frame. I rerouted it and now all is fine. Once again,Chrysler quality shines through...
Thanks,
Bill
Old Oct 5, 2008 | 10:22 PM
what quality was that??? u dont think that some one that changed your brake pads last time could have done that? an 05 I would think u would have changed your pads by now at least once. Plus if that was an issue me personally I would think that it would have caused an issue long b4 now.
Old Oct 9, 2008 | 06:55 PM
billbon8's Avatar
No one touched the brakes just yet. The abs line was pinched between the frame and the brake line. The damage must have been slow wearover time. The engineering was OK but the assembly was poor. For the two vehicles that I've owned, I've seen too many issues of poor assembly quality and cheap materials that don't hold up. If I didn't do most of the repairs myself (or had them addressed under warranty), I would easily have dropped $5K in each vehicle to correct nonsense stuff. That IMHO is completely unsat and perhaps the primary reason that people are foregoing American cars in droves. Just look at any recent Consumer Reports and see how the Americans (especially Chrysler) stack up when compared with foreign makes. It's extremely disappointing when a Hyundai van completely outclasses Chrysler's best. The only bright side is that repair parts are readily availble and usually inexpensive.
Old Apr 26, 2015 | 10:12 AM
Susan Loomis's Avatar
is is dangerous to drive it that way? i have same problem...abs,service engine soon,and wheel censors light from the valve stem on my 2006 town and country
Old Apr 26, 2015 | 12:42 PM
if the lite is on U will not have ABS brakes normal brakes will not be affected.
Nathaniel Karter Keith
Apr 6, 2015 06:58 AM
fragmented
Jan 24, 2013 03:03 PM
J Wikoff
Feb 24, 2012 11:08 PM
dartboy340
Sep 10, 2011 03:02 PM
blong
Mar 31, 2008 10:15 AM
