AC and heater control module
Old Jul 10, 2011 | 05:10 PM
our 05van's Avatar
Default AC and heater control module
Hi, anyone know how to do a diagnostic and calibration test on a 05 T&C that has front and rear AC? Thanks, Dave
Old Jul 10, 2011 | 09:25 PM
what issue are u having?
Old Jul 11, 2011 | 11:30 AM
our 05van's Avatar
Hi, I had the ac control module replaced in May and the ac has not been consistant since. Sometimes it cools fine, other times it does't get real cold, and at times it seems as though it actually is blowing heat. I found in my repair manual that when a module is changed it must be calibrated and a diagnostic preformed. I was wondering if they may if just removed and replaced? Thanks, Dave
Old Jul 11, 2011 | 03:36 PM
A/C COOL DOWN TEST
The heater-A/C control module can perform an A/C cool down test, which is a test performed during the manufacturing process to confirm that the air conditioning system is performing satisfactorily. This test can also provide a quick confirmation of air conditioning system performance to the service technician. If the test is completed satisfactorily, no further service is required. If the test is failed, proceed to the A/C Performance Test to confirm the A/C system is operating properly, or use a DRBIII® scan tool to diagnose the A/C system control and distribution systems. Refer to the appropriate diagnostic information.
MANUAL TEMPERATURE CONTROL
The front blower speed and rear blower speed (if equipped with rear HVAC) must be set to High and the evaporator temperature sensor must be greater than 13° C (55° F) or the test will fail immediately. The test is activated by depressing the A/C and Rear Wipe/Wash buttons simultaneously and holding them depressed for no less than five seconds. The Rear Wipe/Wash and A/C LEDs will blink on and off until the test is complete. If the LEDs stop blinking before two minutes, then the cool down test has been completed successfully. If the two minutes expire without the expansion valve temperature reaching -6° C (20° F) less than the outside air temperature, then the cool down test has been failed and further A/C system diagnosis is required. If the test is failed, the LEDs will continue to blink until the vehicle has been driven for greater than 13 km (8 miles).
AUTOMATIC TEMPERATURE CONTROL
The ambient air temperature in the room where the vehicle will be tested must be a minimum of 21° C (70°F) for this test. The test is activated by depressing the A/C and PWR buttons simultaneously and holding them depressed for no less than four seconds. The snowflake icon and the DELAY text in the ATC display will blink on and off alternately until the test is complete. If the snowflake icon and the DELAY text stop blinking before two minutes, then the cool down test has been completed successfully. If the two minutes expire without the evaporator temperature reaching -6° C (20° F) less than the evaporator initial temperature, then the cool down test has been failed and further A/C system diagnosis is required. If the test is failed, the snowflake icon and the DELAY text will continue to blink across ignition cycles until the vehicle has been driven for greater than 13 km (8 miles).
Old Jul 13, 2011 | 08:52 AM
TNtech's Avatar
Were the symptoms the same BEFORE it was replaced? If it is an ATC then when you first plug the new one into the BUS and apply switch current, they will go into a self calibration.
Bubble_City
May 4, 2009 06:23 PM
burninrice5oh
Nov 19, 2008 10:05 PM
CSPEISER
Jul 24, 2007 11:25 PM
chucktee
Sep 14, 2005 04:15 AM
